Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to replace the rear-facing camera on your Nexus 9.
O que você precisa
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Carefully peel up the copper shielding with your fingers.
Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
Remove the three 3mm T5 Torx screws.
Remove the five 2 mm Phillips #000 screws.
4 outras pessoas executaram este guia.
