Introdução
Use this guide to replace the front-facing camera on your Nexus 9.
O que você precisa
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Use a spudger to disconnect the front-facing camera ZIF connector.
Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
Uma outra pessoa concluiu este guia.
