Introdução
This guide will show you how to replace the power and volume button ribbon cable.
O que você precisa
Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
My Nexus 7 looks nothing like this. These instructions are horrible as they do not work.
someone help? my nexus looks completely different
Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
I have the newer version of Nexus and the battery connection inside is different from pictured here. I can't seem to get any part of the connector backed out. Any further details about how to accomplish this step?
After my post I tried it again, and realized the connector comes straight UP, not OUT. Once I went this direction, the process was simple.
I followed this, everything worked fine. Even though the battery is now charging, the OS doesn't recognise when the USB cable is connected to a wall socket or a PC. The battery icon when the tablet is shut down shows charging so it works, but the OS in itself doesn't seem to know about it...any ideas?
/D
Thanks for your guide. It makes the process very straightforward. Easier than I was expecting.
Yes, this is a really helpful guide. I wouldn't have had a clue without it, but it all turned out to be very simple. Thanks a lot!
Step 6 could be much clearer. I thought it meant to pry the connector upward, away from the surface. When I did this, all the pins broke off. The correct procedure would appear to be to slide the connector along the surface toward the wire side and battery, leaving the pins at parallel to the surface.
Unfortunately I don't think my Nexus 7 is salveagable now.
Watching a YouTube video helped. Dislodge the battery first, then pull the battery away from the connector and the connector will become dislodged quite easily.
Peel back the label covering the power and volume button ZIF connector.
Use the tip of a spudger to carefully flip up the retaining flap on the power and volume button ribbon cable ZIF socket.
Use the tip of a spudger to pull the power and volume button ribbon cable straight out of its socket.
Insert the flat end of a spudger between the power and volume button cable and the metal frame.
Carefully slide the spudger along the length of the ribbon cable, releasing the buttons.
T
4 outras pessoas executaram este guia.
7 comentários
Hi All,
I've been to Orlando/FL this Sept/October and I bought 2 ASUS NEXUS 7 Tablets.
The first one was opened and used there, in Orlando. The second one, is a gift for my wife, and we had just unopened the box (yes, december/11/2012) and for our surprise the device simply do not turned on. I did a search on Internet, and I have opened the device. As we have two devices, I could compare and I noticed that it has a Missing "small flat cable", the one with the function of the buttons (power and volume).
I took a picture of both devices, if you tell me how, I can send you the pictures.
Where can I "buy" this small cable?
Thanks for your support.
The volume buttons on my Nexus 7 (2013) don't work. Is this procedure applicable to the 2013 version and do you think it will solve the problem?
Carl, Its the same fix as the Power& Volume Button Cable in our free guide u downloaded
I done had to fix my screen dog got it. There not to bad to work on.
Where can I buy a power & volume button cable ribbon?
Mine doesn't look like this. There is no metal band around it. The only opening looks like its between the front glass and back which is on the front. I'm afraid to try it for fear of breaking it. Any suggestions?
Kim McCauley - Responder
There is no front or rear panel. There’s no sign of any seam whatsoever. The front and back are one solid piece of plastic.
Proud Liberal - Responder
