Ir para o conteúdo principal
Nexus 7 2nd Generation Back Cover Replacement
O que você precisa
    1. Nexus 7 2nd Generation Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Nexus 7 2nd Generation Back Cover Replacement, Back Cover: passo 1, imagem 2 %32
      • Power down your device.
      • Use your plastic opening tool to wedge between the seams around the sides of the device. Pry open each side, one at a time. For some a finger nail may be best. The case comes up quite high to the glass.
      • Do not pry near the USB port at the base of the device as you may crack the rear panel.
      Pergunte ao FixBot
      Comentar
    2. Nexus 7 2nd Generation Back Cover Replacement: passo 2, imagem 1 %32
      • Work fingers around the seam between device and back cover. Use your plastic opening tool and fingers to separate each side until device and back cover are completely apart.
      • Be careful around the corners. The body of the device can be fragile.
      Pergunte ao FixBot
      Comentar
Conclusão
16 outras pessoas executaram este guia.
Heather
Membro desde: 01/22/15
1.428 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-16, Maness Winter 2015 Membro de Cal Poly, Team 20-16, Maness Winter 2015
CPSU-MANESS-W15S20G16
4 Membros
Autoria de 26 guias
4Comentários do guia
Step left out. ifixit.com video on Youtube show use of craft knife as first step to get into very tight case fitting, then the use of plastic pry tool to go around releasing the backcover.
nodakman84 - Responder Compartilhar
I didnt read the comment about it being tight and using a knife, until I had damaged the prying tools :-(
Bill Walker - Responder Compartilhar
How do u take off the cover do u have to have that tool
Sharon Catalli - Responder Compartilhar
I had very little problem prying of the back of my nexus 7 2012. Once you get the first corner done, the rest comes pretty easy.
I ended up using an old hotel keycard as a spudger and it worked fine.
I needed access to the cables that connect the touchscreen to the motherboard so that my touch screen would respond.
Worked like a charm!
Mister Muscles - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 60
Ao todo: 13,956
