Ir para o conteúdo principal
Nexus 6P Daughterboard/Charging Port Replacement
O que você precisa
Vídeo de Apresentação
  1. Nexus 6P Daughterboard/Charging Port Replacement, Daughterboard/Charging Port: passo 1, imagem 1 %32 Nexus 6P Daughterboard/Charging Port Replacement, Daughterboard/Charging Port: passo 1, imagem 2 %32
    • Remove SIM card tray.
  2. Nexus 6P Daughterboard/Charging Port Replacement: passo 2, imagem 1 %32 Nexus 6P Daughterboard/Charging Port Replacement: passo 2, imagem 2 %32 Nexus 6P Daughterboard/Charging Port Replacement: passo 2, imagem 3 %32
    • Heat up back glass panel.
    • Use hobby knife to open a gap and cut the fierce sticker underneath rear glass panel.
    • The back glass panel is easily shattered and the adhesive underneath is fierce. So be careful to pry this part.
  3. Nexus 6P Daughterboard/Charging Port Replacement: passo 3, imagem 1 %32 Nexus 6P Daughterboard/Charging Port Replacement: passo 3, imagem 2 %32 Nexus 6P Daughterboard/Charging Port Replacement: passo 3, imagem 3 %32
    • Heat up bottom plastic panel.
    • Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath.
  4. Nexus 6P Daughterboard/Charging Port Replacement: passo 4, imagem 1 %32 Nexus 6P Daughterboard/Charging Port Replacement: passo 4, imagem 2 %32 Nexus 6P Daughterboard/Charging Port Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • Twist off 6 Phillips screws together.
    • Insert guitar picks and plastic opening tool to separate front assembly from back cover.
    • Attention: These two parts fit tightly.It is the toughest part to separate. You can also try using heavy-duty suction cup to disassemble them.
  5. Nexus 6P Daughterboard/Charging Port Replacement: passo 5, imagem 1 %32 Nexus 6P Daughterboard/Charging Port Replacement: passo 5, imagem 2 %32 Nexus 6P Daughterboard/Charging Port Replacement: passo 5, imagem 3 %32
    • Unscrew one Phillips screw.
    • Remove metal bracket securing flex contactors.
    • Release 3 flex contactors and remove it .
    • This flex is used to connect motherboard and daughterboard.
  6. Nexus 6P Daughterboard/Charging Port Replacement: passo 6, imagem 1 %32 Nexus 6P Daughterboard/Charging Port Replacement: passo 6, imagem 2 %32 Nexus 6P Daughterboard/Charging Port Replacement: passo 6, imagem 3 %32
    • Disconnect signal cable contactor and twist off one Phillips screw.
    • Remove daughterboard.
  7. Nexus 6P Daughterboard/Charging Port Replacement: passo 7, imagem 1 %32
    • Here is the daughterboard. The charging port is attached here.
Conclusão
23 outras pessoas executaram este guia.
Witrigs
Membro desde: 11/24/15
70.729 Reputação
Autoria de 377 guias
13Comentários do guia
Do you know the part number of the daughterboard, or where I can buy a replacement?
Ezequiel Arneodo - Responder
Global Direct Parts seems to have OEM parts. Don't go with eBay and stuff. The ones I saw are cheap knockoffs that don't work right (even when they say OEM).
Sunny Wu -
Do we need more adhesive or everything will stick back with heat?
Will Taylor - Responder
I have replaced my battery. You most likely will need more adhesive. I just plan on using some double sided tape as the original glue was too tough in case I have to open it again. You can just buy a case for it after. It will keep everything nice and tight on there.
Sunny Wu -
To replace the daugherboard, step #5 can largely be skipped - just remove the cable from the daugherboard and move on to step #6. This phone is a true PITA to take apart.
ashlux - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 74
Ao todo: 18,602
