Introdução
Use this guide to remove the rear panel of your Nexus 5X.
O que você precisa
Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
Press in to eject the SIM card tray.
Remove the SIM card tray.
Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
Here’s a photo of the location of the 18 tabs that hold the back cover in place
Twisting sideways didn’t do it for me, but sliding along the edge did. However, at first I didn’t realize that the pick was between the motherboard and midframe, rather than between midframe and back cover like it was supposed to. This led to breaking off a spring-loaded connector on the motherboard, connecting to an antenna (I guess) in the back cover. So far I haven’t noticed any reception issues, but I can’t say for sure.
In essence: be careful to get the pick towards the back cover, and not “straight in” under the midframe.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
26 outras pessoas executaram este guia.
Um comentário
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
