Ir para o conteúdo principal
Nexus 5X Rear Panel Replacement
O que você precisa
  1. Nexus 5X Rear Panel Replacement, SIM Card Tray: passo 1, imagem 1 %32 Nexus 5X Rear Panel Replacement, SIM Card Tray: passo 1, imagem 2 %32 Nexus 5X Rear Panel Replacement, SIM Card Tray: passo 1, imagem 3 %32
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Rear Panel Replacement, Rear Panel: passo 2, imagem 1 %32 Nexus 5X Rear Panel Replacement, Rear Panel: passo 2, imagem 2 %32 Nexus 5X Rear Panel Replacement, Rear Panel: passo 2, imagem 3 %32
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Nexus 5X Rear Panel Replacement: passo 3, imagem 1 %32 Nexus 5X Rear Panel Replacement: passo 3, imagem 2 %32 Nexus 5X Rear Panel Replacement: passo 3, imagem 3 %32
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Rear Panel Replacement: passo 4, imagem 1 %32 Nexus 5X Rear Panel Replacement: passo 4, imagem 2 %32
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
Conclusão
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
26 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
211.821 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.085 guias
Um comentário
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
Lucas Marti - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 8,748
