Ir para o conteúdo principal
Nexus 5 SIM Card Replacement
O que você precisa
  1. Nexus 5 SIM Card Replacement, SIM Card: passo 1, imagem 1 %32 Nexus 5 SIM Card Replacement, SIM Card: passo 1, imagem 2 %32
    • Power off the device by holding the power button until the "Power Off" popup appears. Tap the popup and wait for the device to turn off.
    • Insert a SIM card eject tool or a paper clip into the hole next to the SIM card slot, which is located just under the power button. Do not force the paper clip if it is too thick; instead use the head of a sewing needle.
    • Push the tool into the hole until you see the card pop out.
  2. Nexus 5 SIM Card Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Gently remove the SIM card with your fingers, or a pair of tweezers if the SIM holder does not fully eject.
    • Make sure the chip is facing the rear of the phone when reinserting the SIM card.
Conclusão
Kyle Libby
Membro desde: 04/07/14
1.006 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 7-23, Regan Spring 2014 Membro de Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
Membros da 4
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 4,126
