Introdução
Use this guide to replace the backplate that secures the motherboard of your Nexus 5.
O que você precisa
Use a plastic opening tool to free the clips on the top and each side of the back cover.
Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
18 outras pessoas executaram este guia.
