Ir para o conteúdo principal
Nexus 5 Antenna Cable Replacement
O que você precisa
  1. Nexus 5 Antenna Cable Replacement, Remove the Battery Door: passo 1, imagem 1 %32
    • The battery door of the Nexus 5 is held together with plastic clips.
    • Use the plastic spudger to separate the battery door.
  2. Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: passo 2, imagem 1 %32 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: passo 2, imagem 2 %32 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: passo 2, imagem 3 %32
    • Using your #00 Philips Screwdriver, remove the six screws holding the midframe in place.
    • Remove the four screws at the bottom of the device holding the speaker assembly in place.
    • The screw on the far right may be covered in adhesive. Use your plastic spudger to remove the adhesive covering the screw.
  3. Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: passo 3, imagem 1 %32 Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: passo 3, imagem 2 %32
    • Remove the midframe and speaker assembly.
  4. Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: passo 4, imagem 1 %32 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: passo 4, imagem 2 %32 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: passo 4, imagem 3 %32
    • The antenna cables are located on the right and left side of the battery (one is gray, the other is black).
    • Using your plastic spudger, disconnect both ends of the antenna cables.
    • Connect your new antenna cables.
    • Make sure the antenna cables are securely connected.
  5. Nexus 5 Antenna Cable Replacement, Reassemble the Device: passo 5, imagem 1 %32 Nexus 5 Antenna Cable Replacement, Reassemble the Device: passo 5, imagem 2 %32
    • Screw the midframe and speaker assembly back into place.
    • Push the outer edges of the battery door down until you hear the plastic clips "click."
    • Hold the power button until you feel the phone vibrate and/or see the Google logo displayed.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Tyler Caldwell
Membro desde: 12/07/17
181 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G1, Baechle Fall 2017 Membro de IUPUI, Team S1-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S1G1
Membros da 2
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 2,782
