Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide shows how to remove the back case from the Nexus 4, giving access to the internal features of the phone. This will take a couple of minutes.
O que você precisa
Ferramenta utilizada nesse passo:SIM Card Eject Tool$2.99
Power off the phone, by long-pressing the power button and touching Power off.
Remove the SIM tray using the SIM Card Eject Tool.
Ferramenta utilizada nesse passo:T5 Torx Screwdriver$5.49
Remove the two screws from the bottom of the phone with a T5 Torx Screwdriver.
48 outras pessoas executaram este guia.
3 comentários
I have made some rearrangement at this guide:
It more logic to remove the tray before removing the screws.
I have used some pictures from the teardown to clarify, particularly for showing the inside of the Nexus 4 showing the battery installed. The original picture did not show the battery. I have also made better reference to the tools.
I ordered the back case using the provided link at etradesupply.com, and noticed it is not an original part: the wireless charging does not work at all (the coil has a much higher resistance than the original one). After insisting, they sent me another one, which gave the same result. Better avoid buying there if you expect original working products...
What about the buttons and the NFC? I can buy a back cover with NFC included, but most seem to not have the buttons. Is it easy to remove the ones from the old cover and install them in the new cover?
