Ir para o conteúdo principal
Nexus 10 Front Facing Camera Replacement
O que você precisa
  1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: passo 1, imagem 1 %32 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: passo 1, imagem 2 %32 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: passo 1, imagem 3 %32
    • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
  2. Nexus 10 Front Facing Camera Replacement: passo 2, imagem 1 %32 Nexus 10 Front Facing Camera Replacement: passo 2, imagem 2 %32 Nexus 10 Front Facing Camera Replacement: passo 2, imagem 3 %32
    • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
    • Pull the the plastic backing off the display assembly using your hands.
    • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
  3. Nexus 10 Front Facing Camera Replacement: passo 3, imagem 1 %32 Nexus 10 Front Facing Camera Replacement: passo 3, imagem 2 %32 Nexus 10 Front Facing Camera Replacement: passo 3, imagem 3 %32
    • Lift latch on front-facing camera connector.
    • Pull the connector toward the top of the device and remove the front-facing camera.
Conclusão
Benjamin Troller
Membro desde: 04/11/16
2.239 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 34-18, Maness Spring 2016 Membro de Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 16
Ao todo: 771
