Ir para o conteúdo principal
Nextplay NP109CR Speakers Replacement
O que você precisa
  1. Nextplay NP109CR Speakers Replacement, Speakers: passo 1, imagem 1 %32
    • Turn the device over so it is upside-down.
  2. Nextplay NP109CR Speakers Replacement: passo 2, imagem 1 %32
    • Unscrew the 4 screws closest to the screen.
  3. Nextplay NP109CR Speakers Replacement: passo 3, imagem 1 %32
    • Flip over the device so it is right side up.
  4. Nextplay NP109CR Speakers Replacement: passo 4, imagem 1 %32
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Nextplay NP109CR Speakers Replacement: passo 5, imagem 1 %32
    • Take off top piece by using slight force and pulling off.
  6. Nextplay NP109CR Speakers Replacement: passo 6, imagem 1 %32
    • Unscrew the button board with smaller screwdriver.
  7. Nextplay NP109CR Speakers Replacement: passo 7, imagem 1 %32
    • Lift off the button board.
  8. Nextplay NP109CR Speakers Replacement: passo 8, imagem 1 %32
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  9. Nextplay NP109CR Speakers Replacement: passo 9, imagem 1 %32
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  10. Nextplay NP109CR Speakers Replacement: passo 10, imagem 1 %32
    • Flip the screen and the logic board over to the right side.
  11. Nextplay NP109CR Speakers Replacement: passo 11, imagem 1 %32
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
Conclusão
Michelle Read
Membro desde: 09/26/12
1 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-50, Forte Fall 2012 Membro de Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 390
