Introdução
With this guide you will be able to successfully remove the damaged or old battery pack.
O que você precisa
To begin, remove the screen from the keyboard.
Open the 2-in-1, and hold the screen.
Press the silver button at the top of the keyboard.
When the screen lifts up, gently lift the screen away from the keyboard.
Removing the back cover will invalidate your warranty.
You may use your fingers, or a spudger. Be careful not to break your cover OR your fingernail. Removing the cover requires good judgement.
The goal is to separate the black from the silver. Start in a corner, or a flat edge -- whichever works best for you. Remember to not use too much force.
Once you start the initial separation, keep going until you free one edge. The goal now is to free three edges of the rectangle.
If your progress stops on one side of the rectangle, go to the other side and try there.
To remove the battery section of the device from the circuit board remove, use the small Phillips head screwdriver for the 3 small screws near the top.
To get the battery pack completely away from the circuit board there is copper foil on the back of the battery.
be careful not to rip the copper foil. Pull the foil slowly an evenly.
4 outras pessoas executaram este guia.
