Ir para o conteúdo principal
Nextbook 8 Screen Replacement
O que você precisa
  1. Nextbook 8 Screen Replacement, Battery: passo 1, imagem 1 %32 Nextbook 8 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Screen Replacement: passo 2, imagem 1 %32 Nextbook 8 Screen Replacement: passo 2, imagem 2 %32
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Screen Replacement: passo 3, imagem 1 %32 Nextbook 8 Screen Replacement: passo 3, imagem 2 %32
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Screen Replacement: passo 4, imagem 1 %32
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Screen Replacement: passo 5, imagem 1 %32 Nextbook 8 Screen Replacement: passo 5, imagem 2 %32
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
  6. Nextbook 8 Screen Replacement, Screen: passo 6, imagem 1 %32
    • Remove the silver and gold sticker at the bottom of the device.
    • Hold the brown circuit board down with your finger while you remove the sticker
  7. Nextbook 8 Screen Replacement: passo 7, imagem 1 %32 Nextbook 8 Screen Replacement: passo 7, imagem 2 %32
    • Use a spudger to lift up the black tabs on the three ZIF connectors.
    • Use ESD safe tweezers to pull the ribbon cables out of the three connectors.
  8. Nextbook 8 Screen Replacement: passo 8, imagem 1 %32 Nextbook 8 Screen Replacement: passo 8, imagem 2 %32
    • Remove the 5 black screws on the motherboard.
    • Carefully lift the motherboard off of the device and remove.
  9. Nextbook 8 Screen Replacement: passo 9, imagem 1 %32 Nextbook 8 Screen Replacement: passo 9, imagem 2 %32
    • Remove the two screws that hold the brackets in place.
    • Remove the two silver brackets that hold the screen in place.
  10. Nextbook 8 Screen Replacement: passo 10, imagem 1 %32 Nextbook 8 Screen Replacement: passo 10, imagem 2 %32
    • Remove the one silver screw on the small green circuit board at the bottom of the device.
    • Set aside the small circuit board for now.
  11. Nextbook 8 Screen Replacement: passo 11, imagem 1 %32
    • Remove the two silver screws from the bottom of the device.
  12. Nextbook 8 Screen Replacement: passo 12, imagem 1 %32 Nextbook 8 Screen Replacement: passo 12, imagem 2 %32 Nextbook 8 Screen Replacement: passo 12, imagem 3 %32
    • With the device face down, use a spudger to lift the screen off of the glass from the right side.
Conclusão
21 outras pessoas executaram este guia.
Dylan Wiese
Membro desde: 03/11/15
1.853 Reputação
Autoria de 5 guias
Equipe
Colorado Springs, Team 5-1, Panko Spring 2015 Membro de Colorado Springs, Team 5-1, Panko Spring 2015
UCCS-PANKO-S15S5G1
Membros da 3
Autoria de 10 guias
Um comentário
where do I find the actual screen though
WiKiT Woo WoNKa - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 23,855
