Ir para o conteúdo principal
Nextbook 8 Battery Replacement
O que você precisa
  1. Nextbook 8 Battery Replacement, Battery: passo 1, imagem 1 %32 Nextbook 8 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
    • Slide the tool along the edge to work the back cover off.
    • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
  2. Nextbook 8 Battery Replacement: passo 2, imagem 1 %32 Nextbook 8 Battery Replacement: passo 2, imagem 2 %32
    • Remove the tape covering the motherboard.
    • Remove the silver tape holding the white ribbon cables to the battery.
  3. Nextbook 8 Battery Replacement: passo 3, imagem 1 %32 Nextbook 8 Battery Replacement: passo 3, imagem 2 %32
    • Use a spudger to carefully disconnect the battery connector from the motherboard.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  4. Nextbook 8 Battery Replacement: passo 4, imagem 1 %32
    • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  5. Nextbook 8 Battery Replacement: passo 5, imagem 1 %32 Nextbook 8 Battery Replacement: passo 5, imagem 2 %32
    • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
    • The battery is very malleable, so do not try to pull it off all at once.
Conclusão
22 outras pessoas executaram este guia.
Dylan Wiese
Membro desde: 03/11/15
1.853 Reputação
Autoria de 5 guias
Equipe
Colorado Springs, Team 5-1, Panko Spring 2015 Membro de Colorado Springs, Team 5-1, Panko Spring 2015
UCCS-PANKO-S15S5G1
Membros da 3
Autoria de 10 guias
4 comentários
Very helpful and well made.
Quentin Freed - Responder
Where can I buy the battery???
scruff67 - Responder
Check Ebay. That's where I'm headed right now.
Tina Carey -
im having connection issues i cant find any wifi period
crusher309 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 42,161
