Ir para o conteúdo principal
NexiGo NS32 Motherboard Replacement
O que você precisa
  1. NexiGo NS32 Motherboard Replacement, Rear Case: passo 1, imagem 1 %32
    • Orient the controller so that it is face down.
  2. NexiGo NS32 Motherboard Replacement: passo 2, imagem 1 %32 NexiGo NS32 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the eight 9 mm Phillips screws that secure the rear case.
  3. NexiGo NS32 Motherboard Replacement: passo 3, imagem 1 %32
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
  4. NexiGo NS32 Motherboard Replacement, Battery: passo 4, imagem 1 %32 NexiGo NS32 Motherboard Replacement, Battery: passo 4, imagem 2 %32
    • Grip the white battery connector and pull it directly out of its motherboard socket.
    • This may require some force, as the connectors are secured with a bit of adhesive. If you're having trouble with disconnection, apply some high-concentration isopropyl alcohol to the adhesive to loosen it.
    • Do not pull on the wires.
  5. NexiGo NS32 Motherboard Replacement: passo 5, imagem 1 %32 NexiGo NS32 Motherboard Replacement: passo 5, imagem 2 %32 NexiGo NS32 Motherboard Replacement: passo 5, imagem 3 %32
    • Lift the battery up and out.
    • Take care not to bend or puncture the battery as you remove it.
  6. NexiGo NS32 Motherboard Replacement, Joystick PCB: passo 6, imagem 1 %32 NexiGo NS32 Motherboard Replacement, Joystick PCB: passo 6, imagem 2 %32
    • Remove the three 9 mm Phillips screws that secure the joystick PCB.
  7. NexiGo NS32 Motherboard Replacement: passo 7, imagem 1 %32 NexiGo NS32 Motherboard Replacement: passo 7, imagem 2 %32
    • Flip up the black ZIF connector locking flap on the left side of the joystick PCB.
    • Pull the ribbon cable directly out of its socket.
  8. NexiGo NS32 Motherboard Replacement: passo 8, imagem 1 %32 NexiGo NS32 Motherboard Replacement: passo 8, imagem 2 %32 NexiGo NS32 Motherboard Replacement: passo 8, imagem 3 %32
    • Lift out the joystick PCB.
  9. NexiGo NS32 Motherboard Replacement, Trigger Assembly: passo 9, imagem 1 %32
    • Flip up the black ZIF locking flap that secures the trigger assembly ribbon cable.
    • Disconnect the ribbon cable.
  10. NexiGo NS32 Motherboard Replacement: passo 10, imagem 1 %32 NexiGo NS32 Motherboard Replacement: passo 10, imagem 2 %32
    • Gently lift out the trigger assembly.
  11. NexiGo NS32 Motherboard Replacement, Motherboard: passo 11, imagem 1 %32 NexiGo NS32 Motherboard Replacement, Motherboard: passo 11, imagem 2 %32
    • Remove the two 9 mm Phillips screws that secure the motherboard to the front case.
  12. NexiGo NS32 Motherboard Replacement: passo 12, imagem 1 %32 NexiGo NS32 Motherboard Replacement: passo 12, imagem 2 %32 NexiGo NS32 Motherboard Replacement: passo 12, imagem 3 %32
    • Gently lift the motherboard up and out the chassis.
    • Take care not to strain the vibration motor cables.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 255
