Introdução
If the device’s pump system has not been calibrated, first reference “Pump Leak Calibration” in the device’s Troubleshooting page. Reference this guide for failure of pump-related calibrations and pre-use check.
For more information on replacing the pump assembly, please refer to page 5-20 in the service manual.
O que você precisa
Position the base assembly so that you may access it.
Using the #1 Phillips screwdriver, unscrew the four screws (SCR3219P in the photo) and the two screws (SCR3232P) securing the base plate.
