Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Before starting the disassembly, remove
The stylus
Any game cartridge
The SD card
Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
Using a spudger, separate the back panel from the front casing by gently prying around the panel.
There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
Using a spudger, lift out the battery.
Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
33 outras pessoas executaram este guia.
6 comentários
Does the 2ds xl have the same as the new 3ds xl
no. the 2ds shares the same battery type as the Nintendo DS and the Nintendo switch pro controller.
Jason -
CTR-003 Battery
Do I need to put a sticky pad on the new battery?
Got the exact screwdriver (Y00 / 1.5 x 50mm) but it doesn‘t fit. What are my options?
