Ir para o conteúdo principal
Network card Replacement
O que você precisa
  1. Network card Replacement, Remove battery: passo 1, imagem 1 %32
    • Be sure to remove the battery to prevent any electrical shortage.
  2. Network card Replacement, Remove the backpanel: passo 2, imagem 1 %32 Network card Replacement, Remove the backpanel: passo 2, imagem 2 %32
    • Loosen all four screws and remove the back panel.
    • Remove the back panel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
  3. Network card Replacement, Remove the antenna wires: passo 3, imagem 1 %32 Network card Replacement, Remove the antenna wires: passo 3, imagem 2 %32
    • In the red circle is the network card
    • Remove the two wires (inside the green circle)
    • the wires are very fragile and need to be removed with care
  4. Network card Replacement, Remove the network card: passo 4, imagem 1 %32
    • Place the spudger as shown in the photo. The network card will pop up. After that you can remove it and replace it with another one
    • The wires are very fragile, be aware!
Conclusão
To reassemble your device, follow these instructions in reverse order. Be sure to connect the wires the same as in step 3.
Robin Koch
Membro desde: 03/25/17
289 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 890
