Ir para o conteúdo principal
Netgear WGR614v9 Motherboard Replacement
O que você precisa
  1. Netgear WGR614v9 Motherboard Replacement, Lower Case: passo 1, imagem 1 %32
    • Rotate the device so that the bottom is facing up.
  2. Netgear WGR614v9 Motherboard Replacement: passo 2, imagem 1 %32 Netgear WGR614v9 Motherboard Replacement: passo 2, imagem 2 %32
    • Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
    • Be careful not to pull the rubber pads all the way out when lifting as they are difficult to reinsert.
  3. Netgear WGR614v9 Motherboard Replacement: passo 3, imagem 1 %32 Netgear WGR614v9 Motherboard Replacement: passo 3, imagem 2 %32
    • Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
  4. Netgear WGR614v9 Motherboard Replacement: passo 4, imagem 1 %32
    • Lift the bottom casing straight up from the router.
  5. Netgear WGR614v9 Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. Netgear WGR614v9 Motherboard Replacement: passo 6, imagem 1 %32 Netgear WGR614v9 Motherboard Replacement: passo 6, imagem 2 %32
    • Separate the motherboard from the top shell by lifting it straight up from the router.
Conclusão
Ryan Murphy
Membro desde: 10/03/11
488 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 21-24, Maness Fall 2011 Membro de Cal Poly, Team 21-24, Maness Fall 2011
CPSU-MANESS-F11S21G24
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 2,241
