Ir para o conteúdo principal
Netgear Arlo Charging Port Replacement
O que você precisa
  1. Netgear Arlo Charging Port Replacement, Plastic Housing: passo 1, imagem 1 %32
    • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
  2. Netgear Arlo Charging Port Replacement: passo 2, imagem 1 %32 Netgear Arlo Charging Port Replacement: passo 2, imagem 2 %32
    • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
  3. Netgear Arlo Charging Port Replacement: passo 3, imagem 1 %32
    • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
  4. Netgear Arlo Charging Port Replacement: passo 4, imagem 1 %32 Netgear Arlo Charging Port Replacement: passo 4, imagem 2 %32 Netgear Arlo Charging Port Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
    • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
    • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
  5. Netgear Arlo Charging Port Replacement: passo 5, imagem 1 %32 Netgear Arlo Charging Port Replacement: passo 5, imagem 2 %32 Netgear Arlo Charging Port Replacement: passo 5, imagem 3 %32
    • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
    • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
    • Once the screws are removed use an opening tool to pry back the second plastic mount.
  6. Netgear Arlo Charging Port Replacement, Lens Assembly: passo 6, imagem 1 %32
    • Remove 4 (6mm) large screws with a J00 screwdriver.
    • There are 2 on each side. This will allow you to remove the clear housing from the white housing.
  7. Netgear Arlo Charging Port Replacement: passo 7, imagem 1 %32 Netgear Arlo Charging Port Replacement: passo 7, imagem 2 %32
    • Once screws are removed, pull apart the clear housing.
    • Remove rod from camera cover.
  8. Netgear Arlo Charging Port Replacement: passo 8, imagem 1 %32 Netgear Arlo Charging Port Replacement: passo 8, imagem 2 %32 Netgear Arlo Charging Port Replacement: passo 8, imagem 3 %32
    • Remove Large ribbon cable first to disconnect front of camera from main body.
    • Remove 4 (3.5mm) small black screws from motherboard of the camera unit.
    • Remove smaller ribbon cable from underneath yellow tape.
  9. Netgear Arlo Charging Port Replacement: passo 9, imagem 1 %32
    • Once all ribbon cables are removed, remove the motherboard and camera assembly by pulling up on the black camera motherboard.
  10. Netgear Arlo Charging Port Replacement, Charging Port: passo 10, imagem 1 %32
    • Remove the 2 (.135") housing screws with a JIS00 screwdriver
  11. Netgear Arlo Charging Port Replacement: passo 11, imagem 1 %32
    • Remove 4 (.135") screws on the inside of the battery compartment using the JIS 00 screwdriver.
  12. Netgear Arlo Charging Port Replacement: passo 12, imagem 1 %32
    • Slide the two halves apart
  13. Netgear Arlo Charging Port Replacement: passo 13, imagem 1 %32
    • Remove the 2 (.135") screws holding the charging port on using the JIS 00 screwdriver.
  14. Netgear Arlo Charging Port Replacement: passo 14, imagem 1 %32 Netgear Arlo Charging Port Replacement: passo 14, imagem 2 %32
    • Remove the ribbon by prying the black ribbon holder up using the opening tool.
    • Pull the ribbon away from the charging port.
Conclusão
Brian Johnson
Membro desde: 03/21/18
187 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S2-G1, Freund Spring 2018 Membro de IUPUI, Team S2-G1, Freund Spring 2018
IUPUI-FREUND-S18S2G1
Membros da 2
Autoria de 4 guias
4 comentários
Great Job, Thank you!
Bob Olive Sr - Responder
Great thanks where did you get the replacement cable please thanks Mike
mikewalters1951 - Responder
where did you get the replacement cable please thanks  BOB
robertwatkins61 - Responder
Any hints on where the new port came from? I have the baby monitor and the port is cheap rubbish and needs replacing. Thanks
David - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 57
Duração total: 5,185
