Ir para o conteúdo principal
Netgear Arlo Battery Replacement
O que você precisa
  1. Netgear Arlo Battery Replacement, Battery: passo 1, imagem 1 %32 Netgear Arlo Battery Replacement, Battery: passo 1, imagem 2 %32 Netgear Arlo Battery Replacement, Battery: passo 1, imagem 3 %32
    • Locate unlock switch on underside of camera and unlock it by sliding it.
    • Once unlocked, slide the cover out and up to open the battery housing.
  2. Netgear Arlo Battery Replacement: passo 2, imagem 1 %32
    • Remove all 4 of the 3.0 Volt batteries from the battery housing.
  3. Netgear Arlo Battery Replacement: passo 3, imagem 1 %32
    • Inspect prongs at the bottom of the battery housing to ensure that they are not bent or broken before replacing the batteries.
Conclusão
Uma outra pessoa concluiu este guia.
Connor Krampen
Membro desde: 01/08/18
399 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G1, Freund Spring 2018 Membro de IUPUI, Team S1-G1, Freund Spring 2018
IUPUI-FREUND-S18S1G1
Membros da 2
Autoria de 6 guias
2 comentários
i am having a problem charging my arlo pro device
JOSEPH J RUTHERFORD - Responder
I am having a problem with one of my cameras not recognizing the batteries. I replace the battery and it says that it’s low. I’ve tried the same battery on another one of my cameras and it has a full life of energy. I am out of warranty but wanted to know if maybe I can take take it somewhere to get fixed and where???
lawendolina - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 60
Duração total: 6,922
