Ir para o conteúdo principal
Nest Protect Backplate Replacement
O que você precisa
    • Remove the Protect from it’s backplate by twisting counterclockwise on the device until it releases.
    • Unscrew the backplate.
    • Battery operated: Fully remove the backplate screws.
    • Hardwired: Slightly remove the backplate screws and twist the backplate.
    • Pull the backplate off the wall.
    • Place the backplate on the wall.
    • Battery Operated: Screw in the backplate.
    • Hardwired: Twist the backplate so it locks into place and snug the screws
    • 1ST Generation: Twist clockwise until it clicks into place
    • 2ND Generation: Twist clockwise until it grips and adjust to fit the wall or ceiling of wall mounted.
Conclusão
Logan
Membro desde: 04/24/19
121 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 2,484
