Ir para o conteúdo principal
Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement
O que você precisa
  1. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Removal from Wall: passo 1, imagem 1 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Removal from Wall: passo 1, imagem 2 %32
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
  2. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Open Display: passo 2, imagem 1 %32
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
  3. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove the back of the display: passo 3, imagem 1 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove the back of the display: passo 3, imagem 2 %32
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
  4. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: passo 4, imagem 1 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: passo 4, imagem 2 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the base connection ribbon cable.: passo 4, imagem 3 %32
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
  5. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Lift battery from the base: passo 5, imagem 1 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Lift battery from the base: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
  6. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the battery from the motherboard: passo 6, imagem 1 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Disconnect the battery from the motherboard: passo 6, imagem 2 %32
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
  7. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: passo 7, imagem 1 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: passo 7, imagem 2 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove battery from the display: passo 7, imagem 3 %32
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
  8. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Locate auto-away sensor: passo 8, imagem 1 %32
    • Locate the auto-away sensor.
  9. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove screws: passo 9, imagem 1 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove screws: passo 9, imagem 2 %32
    • Remove the four 3mm screws with a #0 Phillips screwdriver.
    • Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
  10. Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: passo 10, imagem 1 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: passo 10, imagem 2 %32 Nest Learning Thermostat 2nd Generation Auto-Away Sensor Replacement, Remove auto-away sensor: passo 10, imagem 3 %32
    • Lift the auto-away sensor from motherboard using tweezers.
    • Peel the copper foil gently from the EMI shield.
Conclusão
Justin Curry
Membro desde: 09/23/14
264 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 11-5, Blackwell Fall 2014 Membro de USF Tampa, Team 11-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G5
5 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 2,280
