Ir para o conteúdo principal
Nest Dropcam Pro Micro-USB Port Replacement
O que você precisa
  1. Nest Dropcam Pro Micro-USB Port Replacement, Outer Case: passo 1, imagem 1 %32
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Nest Dropcam Pro Micro-USB Port Replacement: passo 2, imagem 1 %32 Nest Dropcam Pro Micro-USB Port Replacement: passo 2, imagem 2 %32
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Nest Dropcam Pro Micro-USB Port Replacement: passo 3, imagem 1 %32 Nest Dropcam Pro Micro-USB Port Replacement: passo 3, imagem 2 %32
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: passo 4, imagem 1 %32 Nest Dropcam Pro Micro-USB Port Replacement, Motherboard: passo 4, imagem 2 %32
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Nest Dropcam Pro Micro-USB Port Replacement: passo 5, imagem 1 %32 Nest Dropcam Pro Micro-USB Port Replacement: passo 5, imagem 2 %32
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Nest Dropcam Pro Micro-USB Port Replacement: passo 6, imagem 1 %32 Nest Dropcam Pro Micro-USB Port Replacement: passo 6, imagem 2 %32
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Nest Dropcam Pro Micro-USB Port Replacement: passo 7, imagem 1 %32 Nest Dropcam Pro Micro-USB Port Replacement: passo 7, imagem 2 %32
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: passo 8, imagem 1 %32 Nest Dropcam Pro Micro-USB Port Replacement, Micro-USB Port: passo 8, imagem 2 %32
    • Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port.
    • Lift the Micro-USB port away from the motherboard.
Conclusão
4 outras pessoas executaram este guia.
David Foens
Membro desde: 09/03/15
893 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 15-4, Blackwell Fall 2015 Membro de USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
Membros da 3
Autoria de 12 guias
4 comentários
I don't have the soldering tools but I used lazerbond to reattach the old port. I hope all the conductors are touching their counter parts. I haven't plugged it back in yet. Wish me luck.
Kreschendalyn Backus - Responder
Did it work for you?
Michael Candy -
Where can you order the micro-usb charge port for this cam?
Danny Acevedo - Responder
Not sure where you get them but according to one site it uses a Micro USB 2.0 Type B Receptacle.
https://bit.ly/2Kg01z6
Debbie - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 5,711
