Ir para o conteúdo principal
Nest Cam Speaker Replacement
O que você precisa
  1. Nest Cam Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Speaker Replacement: passo 2, imagem 1 %32
    • Open the back panel completely to expose the speaker indicated by the red circle.
  3. Nest Cam Speaker Replacement: passo 3, imagem 1 %32 Nest Cam Speaker Replacement: passo 3, imagem 2 %32 Nest Cam Speaker Replacement: passo 3, imagem 3 %32
    • Remove old speaker gently with a spudger.
    • When placing the new speaker in make sure the prongs are facing the right direction and will connect with the two connector points on the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Jade Weiss
Membro desde: 02/24/16
662 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-1, Leahy Spring 2016 Membro de USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
Membros da 7
Autoria de 10 guias
4 comentários
where can I buy the new replacement speaker part?
Bradley Kang - Responder
Anyone find out the answer to Bradley's question?
Ravi - Responder
I’m curious as well if anyone has found where to obtain replacement/repair parts. Should be simple enough if we can determine the part number of the speaker.. suppose I’ll tear one down real quick to see.
Christopher Monge - Responder
Looking at the speaker without thermal coverings looks like it just has some sound information. “8 ohm 0.5 w”. Next line, “1742 (space) 1”. Third line, “+ S -”.
Looks like electrical info of the speaker. I’ll keep looking!
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 16
Duração total: 2,667
