Introdução
The Nest Cam needs to be mounted on a stand for optimal posistioning. If your Nest Cam refuses to secure itself to the stand or falls off often, the side snap locks may have weakened or broken and need to be replaced.
O que você precisa
Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
Quase terminado!
Conclusão
