Ir para o conteúdo principal
Nest Cam Outdoor S Battery Replacement
O que você precisa
  1. Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: passo 1, imagem 1 %32 Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: passo 1, imagem 2 %32
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Battery Replacement: passo 2, imagem 1 %32
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Battery Replacement: passo 3, imagem 1 %32
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Battery Replacement: passo 4, imagem 1 %32 Nest Cam Outdoor S Battery Replacement: passo 4, imagem 2 %32
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Battery Replacement, Battery: passo 5, imagem 1 %32 Nest Cam Outdoor S Battery Replacement, Battery: passo 5, imagem 2 %32
    • Wedge a nylon spudger between the white outer shell and the battery.
    • Slowly pull the battery away from the plastic camera cover.
    • The battery is only held on with glue.
Conclusão
Uma outra pessoa concluiu este guia.
Phelix Gaudette
Membro desde: 10/28/21
275 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 Membro de UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G6
Membros da 2
Autoria de 4 guias
3 comentários
Do you have the P/N of the battery??
Richard K Yabuki - Responder
Where to buy a replacement battery?
Ted McKenna - Responder
I believe the battery model is GS24 (3.65V, 600 mAh/21.9Wh).
I also saw this on the battery
GPN: G823-00181-01
Dung Huynh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 52
Últimos 30 dias: 190
Duração total: 6,707
