Ir para o conteúdo principal
Nerf Zombie Strike Crossbow Cocking Mechanism Replacement
O que você precisa
  1. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement, Cocking Mechanism: passo 1, imagem 1 %32
    • There are 19 1.0 cm screws.
  2. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: passo 2, imagem 1 %32
    • The cocking device air to be built up inside the Nerf crossbow, which generates the force needed to propel the darts.
  3. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: passo 3, imagem 1 %32
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: passo 4, imagem 1 %32
    • Separate each part of the Nerf crossbow.
  5. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: passo 5, imagem 1 %32
    • Make sure the cocking mechanism is properly aligned with the rest of the Nerf crossbow.
  6. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: passo 6, imagem 1 %32
    • The cocking device needs to be attached to the plunger in order to function properly.
Conclusão
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 3,475
