Ir para o conteúdo principal
Nerf Vortex Vigilon Side Cover Disassembly
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. Nerf Vortex Vigilon Side Cover Disassembly, Removing the outer screws: passo 1, imagem 1 %32 Nerf Vortex Vigilon Side Cover Disassembly, Removing the outer screws: passo 1, imagem 2 %32
    • Remove the twelve #00 1 cm Phillips screws.
    • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
    • Rotate the gun so that the front is facing you to remove the final screw.
  2. Nerf Vortex Vigilon Side Cover Disassembly, Removing the outside cover: passo 2, imagem 1 %32
    • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
    • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
    • The magazine will slide down automatically as you remove the cover.
Conclusão
Cara Pew
Membro desde: 09/29/14
911 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 13-6, Forte Fall 2014 Membro de Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 40
