Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
A damaged safety lever can be replaced by disassembling the gun with a screwdriver.
Peças
Nenhum componente especificado.
  1. The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
    • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
    • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
    • Both sides of the slide will come off when the screws are removed.
  2. Lift both slide pieces off of the gun.
    • Lift both slide pieces off of the gun.
  3. Remove the twelve #00 1 cm Phillips screws. Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
    • Remove the twelve #00 1 cm Phillips screws.
    • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
    • Rotate the gun so that the front is facing you to remove the final screw.
  4. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  5. When removing the cover, the clip attachment and the spring will likely fall out of the gun.
    • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
    • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
    • The magazine will slide down automatically as you remove the cover.
  6. Remove the seven #00 1 cm Phillips screws that attach the inner mechanism to the back cover.
    • Remove the seven #00 1 cm Phillips screws that attach the inner mechanism to the back cover.
    • Remove the #00 1.2 cm Phillips screw located to the right of the white casing.
  7. An orange block will likely fall out as you remove the front cover. The clip and spring will fall out as well, if they have not already. Wiggle the front cover out from under the white piece and lift up from the gun. Pulling the cover off is tricky due to its inner fitting.
    • An orange block will likely fall out as you remove the front cover. The clip and spring will fall out as well, if they have not already.
    • Wiggle the front cover out from under the white piece and lift up from the gun.
    • Pulling the cover off is tricky due to its inner fitting.
    • Be sure to replace the orange block, spring, and clip before this step in reassembly.
  8. The spring, cap, and rotating lever will likely fall out as you remove the inner mechanism.
    • The spring, cap, and rotating lever will likely fall out as you remove the inner mechanism.
    • Disconnect the inner mechanism from the outer cover by lifting the inner mechanism towards you.
    • Be sure to replace the spring, cap, and rotating lever before this step in reassembly.
  9. Rotate the gun so that the top is facing you. Remove the two #00 1 cm Phillips screws holding the white safety cover in place. Lift off the safety cover. Remove the two #00 1 cm Phillips screws holding the white safety cover in place. Lift off the safety cover.
    • Rotate the gun so that the top is facing you.
    • Remove the two #00 1 cm Phillips screws holding the white safety cover in place. Lift off the safety cover.
  10. Pull the lever up on one side with some force until the knobs on the side of the lever pop out of the grooves.
    • Pull the lever up on one side with some force until the knobs on the side of the lever pop out of the grooves.
Conclusão
Uma outra pessoa concluiu este guia.
Cara Pew
Membro desde: 29/09/2014
899 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team 13-6, Forte Fall 2014 Membro de Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 Membros
7 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 1,162
