Ir para o conteúdo principal
Nerf N-Strike Maverick Trigger Repair
O que você precisa
  1. Nerf N-Strike Maverick Trigger Repair, Nerf N-Strike Maverick Trigger Repair: passo 1, imagem 1 %32
    • Remove the 10 screws on the outer shell of the Maverick.
    • Make sure to keep all the screws in a cup or container so they don't get lost.
  2. Nerf N-Strike Maverick Trigger Repair: passo 2, imagem 1 %32 Nerf N-Strike Maverick Trigger Repair: passo 2, imagem 2 %32
    • After removing all of the screws, slowly lift the gray top left piece.
    • The other side of the top left piece can also be taken off.
  3. Nerf N-Strike Maverick Trigger Repair: passo 3, imagem 1 %32
    • Remove the top left screw.
  4. Nerf N-Strike Maverick Trigger Repair: passo 4, imagem 1 %32 Nerf N-Strike Maverick Trigger Repair: passo 4, imagem 2 %32
    • While holding the Maverick down slowly lift the outer shell.
    • Make sure the orientation of the Maverick matches the picture shown.
  5. Nerf N-Strike Maverick Trigger Repair: passo 5, imagem 1 %32 Nerf N-Strike Maverick Trigger Repair: passo 5, imagem 2 %32
    • Remove the screw holding the trigger to the body.
    • When screwing everything back together, remember to re hook the trigger spring.
  6. Nerf N-Strike Maverick Trigger Repair: passo 6, imagem 1 %32 Nerf N-Strike Maverick Trigger Repair: passo 6, imagem 2 %32 Nerf N-Strike Maverick Trigger Repair: passo 6, imagem 3 %32
    • Check the inner chassis around the trigger area. Make sure the springs and parts can move freely.
    • If a part is broken, a replacement will need to be bought or taken from another Maverick.
  7. Nerf N-Strike Maverick Trigger Repair: passo 7, imagem 1 %32 Nerf N-Strike Maverick Trigger Repair: passo 7, imagem 2 %32
    • After examining and fixing the chassis, screw the trigger back onto the body.
    • Hook the upper spring to the metal rod.
  8. Nerf N-Strike Maverick Trigger Repair: passo 8, imagem 1 %32 Nerf N-Strike Maverick Trigger Repair: passo 8, imagem 2 %32 Nerf N-Strike Maverick Trigger Repair: passo 8, imagem 3 %32
    • Replace the outer shell of the Maverick and the top left screw.
    • When reattaching the outer shell, make sure to hold the top left piece as shown in the first picture. This ensures that the spring remains connected to the rod.
    • Screw the top left piece back onto the Maverick.
    • Replace the 10 screws on the Maverick.
Linha de Chegada
David Lim
Membro desde: 09/27/15
137 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 10-3, Green Fall 2015 Membro de Cal Poly, Team 10-3, Green Fall 2015
CPSU-GREEN-F15S10G3
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 2,330
