Introdução
If the blaster doesn't cock properly, the plunger and O-ring assembly may be damaged or broken. In this guide, you will learn how to replace the O-Ring and Plunger from the Nerf N-Strike Firestrike. This requires nothing more than a number 1 Philips screwdriver.
O que você precisa
Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
Without removing the barrel assembly, tilt it slightly upwards.
Slide the plunger out from the air chamber.
3 outras pessoas executaram este guia.
