Ir para o conteúdo principal
Nerf N-Strike Firestrike O-Ring and Plunger Replacement
O que você precisa
  1. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, Remove battery cover: passo 1, imagem 1 %32
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: passo 2, imagem 1 %32 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: passo 2, imagem 2 %32
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, Blaster Casing: passo 3, imagem 1 %32
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: passo 4, imagem 1 %32 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: passo 4, imagem 2 %32
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike O-Ring and Plunger Replacement: passo 5, imagem 1 %32 Nerf N-Strike Firestrike O-Ring and Plunger Replacement: passo 5, imagem 2 %32
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: passo 6, imagem 1 %32 Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: passo 6, imagem 2 %32 Nerf N-Strike Firestrike O-Ring and Plunger Replacement, O-Ring and Plunger: passo 6, imagem 3 %32
    • Without removing the barrel assembly, tilt it slightly upwards.
    • Slide the plunger out from the air chamber.
Conclusão
3 outras pessoas executaram este guia.
Clovis Jahan
Membro desde: 04/23/15
200 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-6, Amido Spring 2015 Membro de Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 4,679
