Introdução
This spring piston mechanism acts as the primary form of energy storage for your blaster to fire darts. When the blaster is cocked, the air-tight piston mechanism is pulled back and the large spring is compressed, holding in potential energy. Once the blaster is triggered, the energy from the spring pushes the piston forward towards the front of the blaster. Because the piston is air-tight against the walls of the chamber, it pushes all of the air out towards the opening in the front. As this air exits the chamber, it then pushes the dart out of the barrel. If any issues exist with this device, it is usually with the chamber being air-tight. If any air is allowed to exit otherwise, it greatly reduces the effectiveness of the blaster.
O que você precisa
Once the screws have been removed, lift the top half of the gun off.
Take care and try not to lose any smaller pieces as you open it up.
Locking tab for attachments.
what is a locking tab? and where do i see it? sorry my english is bad
its the front sight post
First, remove the outer parts of the blaster, starting with the top part of the cocking mechanism. Then remove the full cover itself.
This is the spring that controls the air compressor. If it is damaged you have found your problem. Replace this spring and the blaster should work.
When I removed the compressor unit I found the little orange plastic needle on the tip was sticking ever so slightly when I pushed on it. I used a cotton swab and rubbing alcohol to clean inside, reassembled, and now it works like a charm!
I did everything you said but my blaster still doesn`t work. But all things are still working so nothing is broken. Why does it not work although??
I dont know wats the problem sometimes it rotates sometimes not sometimes i fires sometimes it does not
7 outras pessoas executaram este guia.
4 comentários
mi nerf strongarm no dispara los dardos con la misma potencia que cuando la utilice por primera vez, dispara los dardos demasiado suave
Maybe the problem is the dards.
what is the size of the spring?
