Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide is going to show you how to take apart the blaster to reach the spring that is located in cocking mechanism of the Nerf.
O que você precisa
Remove the screw on the inside of the gun.
Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
17 outras pessoas executaram este guia.
20 comentários
Where does the locking tab in step 5 go
on the top of the gun(Seeing from the position as if you're aiming)
Its only there for accesory so it still works if you don't return it
chanisco -
