Ir para o conteúdo principal
Introdução
This guide is going to show you how to take apart the blaster to reach the spring that is located in cocking mechanism of the Nerf.
Peças
Nenhum componente especificado.
  1. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement, Outer Shell: passo 1, imagem 1 %32 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement, Outer Shell: passo 1, imagem 2 %32
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 2, imagem 1 %32 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 2, imagem 2 %32
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 3, imagem 1 %32
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 4, imagem 1 %32
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 5, imagem 1 %32
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
  6. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement, Cocking Mechanisim: passo 6, imagem 1 %32 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement, Cocking Mechanisim: passo 6, imagem 2 %32
    • Remove the screw on the inside of the gun.
    • Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  7. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 7, imagem 1 %32 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 7, imagem 2 %32
    • Remove the barrel from the blaster.
    • Remove the front component from the blaster.
    • Both components do not need any tools to be removed.
  8. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 8, imagem 1 %32 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 8, imagem 2 %32 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 8, imagem 3 %32
    • First, remove the trigger.
    • Then remove the cocking holdback.
    • Then remove the air compressor chamber.
  9. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 9, imagem 1 %32 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 9, imagem 2 %32 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: passo 9, imagem 3 %32
    • Locate and remove the indicated screw.
    • This is the spring controlling the cocking mechanism. If the spring is damaged, replace it.
Conclusão
15 outras pessoas concluíram este guia.
Chelsea Ebey
Membro desde: 27/08/2015
390 Reputação
Autoria de 1 guia
USF Tampa, Team 5-4, Blackwell Fall 2015 Membro de USF Tampa, Team 5-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G4
4 Membros
12 Guias de autoria
18 Comments
That screw holding the spring on the cocking mechanism, I accidently misplaced that, can you tell me what type of screw it is so I could buy a replacement.
Cheers :D
HNK - Responder
Where does the locking tab in step 5 go
ryandavidseeweizhi - Responder
on the top of the gun(Seeing from the position as if you're aiming)
Its only there for accesory so it still works if you don't return it
chanisco -
butt my spring was not damaged so whats wrong then?
Cryo - Responder
The catch piece that catches the trigger slide broke when the kids dropped it while cocked. I tried gorrila gluing the very small platic nubs back on but they couldnt hold the spring pressure when cocked and broke again. Where can i buy parts?
kris_866 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 31
Últimos 30 dias: 159
Duração total: 25,116
