Ir para o conteúdo principal
Nerf N-Strike Elite Strongarm Barrel Replacement
O que você precisa
  1. Nerf N-Strike Elite Strongarm Barrel Replacement, Outer Shell: passo 1, imagem 1 %32 Nerf N-Strike Elite Strongarm Barrel Replacement, Outer Shell: passo 1, imagem 2 %32
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Nerf N-Strike Elite Strongarm Barrel Replacement: passo 2, imagem 1 %32 Nerf N-Strike Elite Strongarm Barrel Replacement: passo 2, imagem 2 %32
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Nerf N-Strike Elite Strongarm Barrel Replacement: passo 3, imagem 1 %32
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. Nerf N-Strike Elite Strongarm Barrel Replacement: passo 4, imagem 1 %32
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Nerf N-Strike Elite Strongarm Barrel Replacement: passo 5, imagem 1 %32
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
    what is a locking tab? and where do i see it? sorry my english is bad
    JoseRafael - Responder
    its the front sight post
    Seth Mains - Responder
  6. Nerf N-Strike Elite Strongarm Barrel Replacement, Barrel: passo 6, imagem 1 %32
    • Start by inspecting the barrel closer for broken components.
    • Pressing the unloading button is a good test to check if the barrel will rotate out.
    • If the barrel fails to cooperate, continue onto the next steps.
  7. Nerf N-Strike Elite Strongarm Barrel Replacement: passo 7, imagem 1 %32
    • Once the cover is off, the barrel component will be free and removable.
  8. Nerf N-Strike Elite Strongarm Barrel Replacement: passo 8, imagem 1 %32
    • Once the barrel is removed, continue by removing the front shaft. This component is also independent of the blaster and does not require tools.
  9. Nerf N-Strike Elite Strongarm Barrel Replacement: passo 9, imagem 1 %32
    • Look for any signs of debris or any damaged locations that may be causing the barrel to lock.
  10. Nerf N-Strike Elite Strongarm Barrel Replacement: passo 10, imagem 1 %32
    • At this time, all components interacting with the barrel are removed.
    • Take this time to inspect the barrel for any signs of debris or damaged locations.
Conclusão
9 outras pessoas executaram este guia.
Alexander Kim
Membro desde: 08/27/15
832 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 5-4, Blackwell Fall 2015 Membro de USF Tampa, Team 5-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G4
Membros da 4
Autoria de 12 guias
Um comentário
hi my barrel keeps ritating and is not fixed and does not stay aligned to the shooting point what shall i do
cryo17 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 25
Duração total: 12,176
