Ir para o conteúdo principal
Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement
O que você precisa
  1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: passo 1, imagem 1 %32 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: passo 1, imagem 2 %32
    • Remove three screws with a Phillips #1 screwdriver.
    • Remove the pump grip.
  2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 2, imagem 1 %32
    • Remove thirteen highlighted screws using a Phillips #1 screwdriver.
    • The top rail has shorter screws than the rest.
    • Some of these are captive screws and cannot be removed.
  3. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 3, imagem 1 %32 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 3, imagem 2 %32 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 3, imagem 3 %32
    • Remove the backside by sliding the plastic spudger across the seam.
    • There are loose parts that can fall out. Take these off and put them aside.
  4. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 4, imagem 1 %32 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 4, imagem 2 %32 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 4, imagem 3 %32
    • Separate the trigger mechanism from the barrel.
  5. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 5, imagem 1 %32 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 5, imagem 2 %32 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 5, imagem 3 %32
    • Remove the plunger springs from the mechanism by pulling one of the springs back then bending it off the connection.
    • These are tricky to remove, so be careful when pulling them off.
  6. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 6, imagem 1 %32 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: passo 6, imagem 2 %32
    • Now pull the springs out and add new ones.
    • There are a few pieces with springs that can misalign in reassembly. Keep in mind where they are.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 54
Duração total: 2,593
