Ir para o conteúdo principal
Nerf N-Strike Elite Retaliator Case Disassembly
O que você precisa
  1. Nerf N-Strike Elite Retaliator Case Disassembly, Case Disassembly: passo 1, imagem 1 %32
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Case Disassembly: passo 2, imagem 1 %32
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Case Disassembly: passo 3, imagem 1 %32
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Case Disassembly: passo 4, imagem 1 %32 Nerf N-Strike Elite Retaliator Case Disassembly: passo 4, imagem 2 %32
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Case Disassembly: passo 5, imagem 1 %32 Nerf N-Strike Elite Retaliator Case Disassembly: passo 5, imagem 2 %32
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
Linha de Chegada
28 outras pessoas executaram este guia.
ericharman
Membro desde: 03/02/16
1.410 Reputação
Autoria de 5 guias
14 comentários
How do I clean the slider track?
devinwhaley - Responder
you probably should not do that. i think its oily for a reason.
one smol birb -
You shouldn't. That oily substance is lubricant, which is crucial for smooth functionality.
SirMikay -
Mine had a chopped off dart head stuck in the trigger mechanism.
I had to partially disassemble in order to be able to free the slide which was covering 1 screw.
Overall, it was very easy. Only challenge is keeping track of the screws, as they're not all the same.
Pete Isaacs - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 154
Duração total: 34,775
