Introdução
A worn plunging mechanism can limit your effective firing range. Nobody has time for that. Use this guide to disassemble the blaster and replace the plunger and air chamber.
O que você precisa
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
Removed every screw and gun does not separate. not showing the seperation of the gun makes this tutorial completely useless.
You have to remove the thing you use to ready it
it's very helpful that the troubleshooting for slider won't move backwards goes to "Another two must be removed with the sliding mechanism in the back position." How, just how do you do that if it's jammed
please help if you can
definitely not angry at the troubleshooting page
While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
16 outras pessoas executaram este guia.
4 comentários
Where did we found the pièces??
where i can buy for spare part “air chamber”?
this tutorial helped A LOT
