Ir para o conteúdo principal
Nerf N-Strike Elite Retaliator Barrel Replacement
O que você precisa
  1. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel: passo 1, imagem 1 %32
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Grip: passo 2, imagem 1 %32
    • Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
    • This may require more force than anticipated.
  3. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel Cap: passo 3, imagem 1 %32
    • Disassemble the orange barrel cap by removing two 8mm Phillips screws.
  4. Nerf N-Strike Elite Retaliator  Barrel Replacement, Disassemble Barrel Assembly: passo 4, imagem 1 %32
    • Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
    • There are springs that may become displaced when the barrel housing is removed. Proceed with caution.
  5. Nerf N-Strike Elite Retaliator  Barrel Replacement, Replace Barrel: passo 5, imagem 1 %32
    • Remove the orange barrel from the assembly.
Conclusão
6 outras pessoas executaram este guia.
ericharman
Membro desde: 03/02/16
1.410 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 32
Duração total: 11,353
