Ir para o conteúdo principal
Nerf N-Strike Elite Hail-Fire Trigger Replacement
O que você precisa
  1. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Left Shell: passo 1, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Left Shell: passo 1, imagem 2 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Left Shell: passo 1, imagem 3 %32
    • Before disassembling your Nerf Hail-Fire, be sure to remove the batteries.
    • Remove the two 9.0 mm Phillips screws securing the battery compartment.
    • Slide the battery compartment out.
  2. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 2, imagem 1 %32
    • Remove the five 9.0 mm Phillips screws securing the trigger.
  3. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 3, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 3, imagem 2 %32
    • Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
    • Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
  4. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 4, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 4, imagem 2 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 4, imagem 3 %32
    • Remove both halves of the ring by tugging on it upwards until the lock gets freed.
    • This requires quite a bit of force and if you are not careful, you may break the plastic lock.
  5. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 5, imagem 1 %32
    • Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
  6. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 6, imagem 1 %32
    • Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
  7. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 7, imagem 1 %32
    • Remove the three 9.0 mm Phillips screws holding together the firing chamber.
    • Remove the single 7.0 mm Phillips screw below the barrel.
    • Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
  8. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 8, imagem 1 %32
    • Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
  9. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 9, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 9, imagem 2 %32
    • Remove the two 9.0 mm Phillips screws holding together the handle.
    • Remove the plastic cover of the handle.
  10. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 10, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 10, imagem 2 %32
    • Insert one plastic opening tool inside one side of the orange part depicted in the picture.
    • Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
  11. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 11, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 11, imagem 2 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 11, imagem 3 %32
    • Pull one end of the handle away from the orange latch.
    • Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
  12. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 12, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 12, imagem 2 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 12, imagem 3 %32
    • Lift the entire left shell slowly. The process should be easy and if there is any resistance, there is something wrong. You may have forgotten a screw.
    • Completely remove the left shell from the rest of the Nerf Gun.
  13. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Inner Plastic Components: passo 13, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Inner Plastic Components: passo 13, imagem 2 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Inner Plastic Components: passo 13, imagem 3 %32
    • Remove the cartridge support.
  14. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 14, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 14, imagem 2 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 14, imagem 3 %32
    • Remove the handle crank.
  15. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 15, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 15, imagem 2 %32
    • Remove the clear plastic barrel cover.
  16. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 16, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 16, imagem 2 %32
    • Remove the firing pin.
  17. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Right Shell: passo 17, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Right Shell: passo 17, imagem 2 %32
    • Lift the trigger mechanism out of the shell.
    • You cannot fully remove the trigger mechanism just yet. However taking it out of the shell helps in later steps.
  18. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 18, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 18, imagem 2 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 18, imagem 3 %32
    • Remove the two 9.0 mm Phillips screws.
  19. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 19, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 19, imagem 2 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 19, imagem 3 %32
    • To remove the motor and trigger mechanism you have to detach these two wires which are glued to the shell.
    • Hold close to the wire and pull upward slowly.
    • If you pull too quickly you can potentially damage the wire.
  20. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 20, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 20, imagem 2 %32
    • Once all the pieces are removed the right shell should be fully accessible.
  21. Nerf N-Strike Elite Hail-Fire Trigger Replacement, Trigger: passo 21, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Trigger: passo 21, imagem 2 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement, Trigger: passo 21, imagem 3 %32
    • Remove the single 9.0 mm Phillips screw.
  22. Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 22, imagem 1 %32 Nerf N-Strike Elite Hail-Fire Trigger Replacement: passo 22, imagem 2 %32
    • Locate the orange bar protruding from the rest of the gun. You should see the spring hooked onto two ends.
    • Push the orange bar until the spring becomes loose.
    • The trigger should come loose right away.
Conclusão
Uma outra pessoa concluiu este guia.
Chris
Membro desde: 01/24/14
273 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-13, Regan Winter 2014 Membro de Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 Membros
Autoria de 7 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 2,433
