Introdução
Use this guide to detach the damaged left shell so you'll be able to replace it with an undamaged shell. This guide can also be used with the 5 other Nerf N-Strike Elite Hail-Fire guides to replace other parts.
O que você precisa
Remove the two 9.0 mm Phillips screws securing the battery compartment.
Slide the battery compartment out.
Uma outra pessoa concluiu este guia.
