Ir para o conteúdo principal
Nerf N-Strike Elite Hail-Fire Battery Replacement
O que você precisa
  1. Nerf N-Strike Elite Hail-Fire Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the two 9.0 mm Phillips screws from the battery compartment.
  2. Nerf N-Strike Elite Hail-Fire Battery Replacement: passo 2, imagem 1 %32
    • Pull the battery compartment out and away from the gun.
  3. Nerf N-Strike Elite Hail-Fire Battery Replacement: passo 3, imagem 1 %32
    • Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
  4. Nerf N-Strike Elite Hail-Fire Battery Replacement: passo 4, imagem 1 %32
    • Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
  5. Nerf N-Strike Elite Hail-Fire Battery Replacement: passo 5, imagem 1 %32
    • When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
Conclusão
6 outras pessoas executaram este guia.
Jonathan Peck
Membro desde: 01/24/14
217 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 13-13, Regan Winter 2014 Membro de Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 Membros
Autoria de 7 guias
1Comentário do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 69
Ao todo: 26,441
