Ir para o conteúdo principal
Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement
O que você precisa
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: passo 1, imagem 1 %32 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: passo 1, imagem 2 %32 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: passo 1, imagem 3 %32
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: passo 2, imagem 1 %32 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: passo 2, imagem 2 %32 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: passo 2, imagem 3 %32
    • With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: passo 3, imagem 1 %32 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: passo 3, imagem 2 %32
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: passo 4, imagem 1 %32 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: passo 4, imagem 2 %32 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: passo 4, imagem 3 %32
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, use a spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: passo 5, imagem 1 %32 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: passo 5, imagem 2 %32
    • Remove the two 5mm phillips screws from the rifle muzzle.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: passo 6, imagem 1 %32
    • Remove the muzzle and barrel from the rifle body.
  7. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: passo 7, imagem 1 %32
    • Separate the muzzle from the barrel.
Conclusão
Uma outra pessoa concluiu este guia.
Elizabeth Coffey
Membro desde: 01/26/14
404 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-35, Maness Winter 2014 Membro de Cal Poly, Team 10-35, Maness Winter 2014
CPSU-MANESS-W14S10G35
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 5,838
