Introdução
One of the lesser known pieces to the Nerf N-Strike Deploy CS-6 device is the dart tooth. Other than the internal spring, the dart tooth is what helps aid in firing the darts. If there is any incorrect adjustments or damage to the dart tooth, the device will not function properly unless the pieces are properly replaced. This guide will aid you in ensuring the dart tooth function properly for the device.
O que você precisa
Extend the device in Stealth Mode by pressing the button found on the handle.
Place back on the orange piece with the spring to its original spot on the dart tooth.
While setting in the dart tooth back into place, the small spring on the yellow piece must be placed in its compartment as shown.
Place back cover pieces in order to secure the screws back into place.
