Ir para o conteúdo principal
Nerf Mega Magnus Spring Replacement
O que você precisa
  1. Nerf Mega Magnus Spring Replacement, Spring: passo 1, imagem 1 %32 Nerf Mega Magnus Spring Replacement, Spring: passo 1, imagem 2 %32 Nerf Mega Magnus Spring Replacement, Spring: passo 1, imagem 3 %32
    • Start by removing the (4) exterior Phillips screws from the shell of the gun with a #1 Phillips Screwdriver.
  2. Nerf Mega Magnus Spring Replacement: passo 2, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 2, imagem 2 %32
    • Pulling upward from the rest of the shell, carefully remove the half of the slide facing you.
  3. Nerf Mega Magnus Spring Replacement: passo 3, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 3, imagem 2 %32 Nerf Mega Magnus Spring Replacement: passo 3, imagem 3 %32
    • On the same side, remove all (9) screws from the body of the blaster as shown.
  4. Nerf Mega Magnus Spring Replacement: passo 4, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 4, imagem 2 %32
    • Lift up on the top half of the shell with deliberate force. This should reveal the internals.
  5. Nerf Mega Magnus Spring Replacement: passo 5, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 5, imagem 2 %32 Nerf Mega Magnus Spring Replacement: passo 5, imagem 3 %32
    • Remove the screws from the trigger mechanism and lift it upward
  6. Nerf Mega Magnus Spring Replacement: passo 6, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 6, imagem 2 %32
    • Locate the small grey piece under the plunger tube and remove the screw.
  7. Nerf Mega Magnus Spring Replacement: passo 7, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 7, imagem 2 %32 Nerf Mega Magnus Spring Replacement: passo 7, imagem 3 %32
    • Locate the screws on the return spring. Using a counterclockwise rotation, remove both of the screws.
  8. Nerf Mega Magnus Spring Replacement: passo 8, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 8, imagem 2 %32
    • Using a small tool, carefully remove the spring from its pegs.
  9. Nerf Mega Magnus Spring Replacement: passo 9, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 9, imagem 2 %32 Nerf Mega Magnus Spring Replacement: passo 9, imagem 3 %32
    • Locate the screws behind the dart pusher mechanism. Carefully remove each screw.
  10. Nerf Mega Magnus Spring Replacement: passo 10, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 10, imagem 2 %32 Nerf Mega Magnus Spring Replacement: passo 10, imagem 3 %32
    • Pull upwards on the dart pusher and spring to remove them.
  11. Nerf Mega Magnus Spring Replacement: passo 11, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 11, imagem 2 %32
    • Lift up on the magazine plate in order to remove it.
  12. Nerf Mega Magnus Spring Replacement: passo 12, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 12, imagem 2 %32 Nerf Mega Magnus Spring Replacement: passo 12, imagem 3 %32
    • Pull upward on the dart lip and it will lift off.
  13. Nerf Mega Magnus Spring Replacement: passo 13, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 13, imagem 2 %32 Nerf Mega Magnus Spring Replacement: passo 13, imagem 3 %32
    • Lift the left side of the plunger tube from its peg and the rest will slide off the spring peg.
  14. Nerf Mega Magnus Spring Replacement: passo 14, imagem 1 %32 Nerf Mega Magnus Spring Replacement: passo 14, imagem 2 %32 Nerf Mega Magnus Spring Replacement: passo 14, imagem 3 %32
    • Slide the spring off its peg. If the spring is damaged, replace it.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 3,570
