Ir para o conteúdo principal
Nerf Dart Tag Swarmfire Motor Spring Replacement
O que você precisa
  1. Nerf Dart Tag Swarmfire Motor Spring Replacement, Motor Spring Replacement: passo 1, imagem 1 %32 Nerf Dart Tag Swarmfire Motor Spring Replacement, Motor Spring Replacement: passo 1, imagem 2 %32
    • Using the JIS #1 screwdriver, loosen the nine screws, holding the outer yellow shell in place
    • The screwdriver you'll be using is a J1 head from the 64 Bit Kit.
    • Be sure to sure to use the Magnetic Project Mat to prevent loss of the screws.
  2. Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 2, imagem 1 %32
    • Lift off the outer yellow shell.
  3. Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 3, imagem 1 %32 Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 3, imagem 2 %32 Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 3, imagem 3 %32
    • Remove the screw holding the battery compartment shut.
    • Lift off the inner blue casing
  4. Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 4, imagem 1 %32 Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 4, imagem 2 %32 Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 4, imagem 3 %32
    • Lift off the blue casing, exposing the white motor spring compartment.
    • Loosen and remove the three screws holding the white compartment door shut.
  5. Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 5, imagem 1 %32 Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 5, imagem 2 %32
    • Unsnap the white compartment into two pieces.
  6. Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 6, imagem 1 %32 Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 6, imagem 2 %32 Nerf Dart Tag Swarmfire Motor Spring Replacement: passo 6, imagem 3 %32
    • Remove the motor spring located inside the rotating barrel and replace.
Conclusão
Sonal Purohit
Membro desde: 07/25/16
115 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 876
